주요 콘텐츠로 건너뛰기
Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable
필요한 것
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable, Unplug: 1 단계, 이미지 1/1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 2 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 2 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 2 단계, 이미지 3/3
    • Remove the handle, unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 3 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 3 단계, 이미지 2/2
    • Pry the tape off.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 4 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 4 단계, 이미지 2/2
    • Unscrew the screws to open the hull.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 5 단계, 이미지 1/1
    • Remove the two screws that block the cable.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 6 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 6 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 6 단계, 이미지 3/3
    • Release the brown cable.
    • Unscrew the screw on the domino.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 7 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 7 단계, 이미지 2/2
    • Then release the blue cable.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 8 단계, 이미지 1/1
    • Remove the old cable and replace it with the new one.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 9 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 9 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 9 단계, 이미지 3/3
    • Put the cables back in their place and screw the domino and switch. Then put each room back into their home.
    • The brown cable must be positioned below.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 10 단계, 이미지 1/1
    • Close and screw the device.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 11 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 11 단계, 이미지 2/2
    • Replace the band and handle.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 99
