주요 콘텐츠로 건너뛰기
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
필요한 것
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: 1 단계, 이미지 1/1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 2 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 2 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 2 단계, 이미지 3/3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 3 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 3 단계, 이미지 2/2
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 4 단계, 이미지 1/1
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 5 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 5 단계, 이미지 2/2
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 6 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 6 단계, 이미지 2/2
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 8 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 8 단계, 이미지 2/2
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 10 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 10 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 10 단계, 이미지 3/3
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 13 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 13 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 13 단계, 이미지 3/3
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 14 단계, 이미지 1/1
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 15 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 15 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 15 단계, 이미지 3/3
    • Replace the tip, strip and handle.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 147
