주요 콘텐츠로 건너뛰기
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
필요한 것
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: 1 단계, 이미지 1/1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 2 단계, 이미지 1/2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 2 단계, 이미지 2/2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 3 단계, 이미지 1/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 3 단계, 이미지 2/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 3 단계, 이미지 3/3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 4 단계, 이미지 1/2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 4 단계, 이미지 2/2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 9 단계, 이미지 1/1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 11 단계, 이미지 1/2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 11 단계, 이미지 2/2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 13 단계, 이미지 1/1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 14 단계, 이미지 1/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 14 단계, 이미지 2/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 14 단계, 이미지 3/3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 17 단계, 이미지 1/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 17 단계, 이미지 2/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 17 단계, 이미지 3/3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 18 단계, 이미지 1/1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 20 단계, 이미지 1/2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 20 단계, 이미지 2/2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 21 단계, 이미지 1/1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 22 단계, 이미지 1/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 22 단계, 이미지 2/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 22 단계, 이미지 3/3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 24 단계, 이미지 1/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 24 단계, 이미지 2/3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 24 단계, 이미지 3/3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 25 단계, 이미지 1/2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 25 단계, 이미지 2/2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 26 단계, 이미지 1/1
    • Finally, reposition the vacuum bag.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 146
