주요 콘텐츠로 건너뛰기
Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable
필요한 것
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable, Unplug: 1 단계, 이미지 1/1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 2 단계, 이미지 1/2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 2 단계, 이미지 2/2
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 3 단계, 이미지 1/2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 3 단계, 이미지 2/2
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 4 단계, 이미지 1/3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 4 단계, 이미지 2/3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 4 단계, 이미지 3/3
    • Remove the switch from his housing in order to have access to it.
    • Unscrew the two screws to disconnect the cables.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 5 단계, 이미지 1/3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 5 단계, 이미지 2/3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 5 단계, 이미지 3/3
    • Replace the cable and reconnect the cables to the switch.
    • Be careful to put the sheath back between the two studs.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 6 단계, 이미지 1/1
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 7 단계, 이미지 1/2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: 7 단계, 이미지 2/2
    • Replace the external flange, the protective cover and the side handle.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 99
