주요 콘텐츠로 건너뛰기
Diagnose A Samsung Galaxy A40 Charging Problem
동영상 개요
  1. Diagnose A Samsung Galaxy A40 Charging Problem, +5V line: 1 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem, +5V line: 1 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem, +5V line: 1 단계, 이미지 3/3
    • This is the +5V line from the Charging port to the Motherboard.
  2. Diagnose A Samsung Galaxy A40 Charging Problem, Back cover removal.: 2 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem, Back cover removal.: 2 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem, Back cover removal.: 2 단계, 이미지 3/3
    • Worm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the middle frame.
  3. Diagnose A Samsung Galaxy A40 Charging Problem, Fingerprint sensor: 3 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem, Fingerprint sensor: 3 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem, Fingerprint sensor: 3 단계, 이미지 3/3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. Diagnose A Samsung Galaxy A40 Charging Problem, Middle frame removal: 4 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem, Middle frame removal: 4 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem, Middle frame removal: 4 단계, 이미지 3/3
    • ''Use plastic tool to separate the middle frame. Start from the SIM Tray hole.'
    • First of all disconnect the battery.
  5. Diagnose A Samsung Galaxy A40 Charging Problem, Measurement: 5 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem, Measurement: 5 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem, Measurement: 5 단계, 이미지 3/3
    • Disconnect the Main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the the large end pins of the FPC connector of the Charging board (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the Main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. Diagnose A Samsung Galaxy A40 Charging Problem: 6 단계, 이미지 1/3 Diagnose A Samsung Galaxy A40 Charging Problem: 6 단계, 이미지 2/3 Diagnose A Samsung Galaxy A40 Charging Problem: 6 단계, 이미지 3/3
    • Remove the adhesive rubber.
    • Use some flux and soldering iron to re-solder the first pin of the Mother board FPC.
결론
다른 3명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
189,604 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
314 회원들
안내서 1,322개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 54
30일 전: 154
전체 시간: 6,629
