주요 콘텐츠로 건너뛰기
Diagnosing and Erasing Hard Drives
필요한 것
  1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 1 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 1 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 1 단계, 이미지 3/3
    • If the drive is not installed in a PC, a USB adapter can be used. If you are using an M.2 SSD (NVMe or SATA) you will need a different enclosure than shown in these guide photos.
    • If the hard drive is not installed and you do not have a USB adapter, it can be plugged into a motherboard.
  2. Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 2 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 2 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 2 단계, 이미지 3/3
    • While high hours are not an indication of failure, the odds of a failure are much higher.
    • GSmartControl can be used in Ubuntu if you cannot read the output from Disks.
    • Boot your system into a live Ubuntu session. Locate the Disks application and select the suspicious hard drive.
    • From the drop-down menu, select SMART Data and Self Tests. This will pull up the SMART data.
    • Locate the following SMART attributes: Power On Hours and Power Cycle Count.
  3. Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 3 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 3 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 3 단계, 이미지 3/3
    • If the Reallocated Sector Count is highlighted with a high count, REPLACE THE DRIVE; they are prone to failure and unexpected capacity loss! While SMART Extended is better, a quick test may be sufficient.
    • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
    • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
  4. Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 4 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 4 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 4 단계, 이미지 3/3
    • Select Disks from the desktop to open GSmartControl.
    • Select the hard disk you want to test. Click Attributes to read the SMART data.
    • Locate the following attributes: Power On Time and Power Cycle Count.
  5. Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 5 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 5 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 5 단계, 이미지 3/3
    • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
    • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
  6. Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 6 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 6 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 6 단계, 이미지 3/3
    • Use the error log and SMART data together to diagnose drive problems.
    • Check the error log for drive errors. Click the Error log tab, and review the logs.
    • In the Error log, review the available errors. Read these logs if any are found.
  7. Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 7 단계, 이미지 1/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 7 단계, 이미지 2/3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 7 단계, 이미지 3/3
    • When possible, avoid sector-wiping SSDs. This will reduce the drive liftetime and can be drastic on older 75TBW SSDs.
    • Your erase options will be limited to the Security Set options supported in the drive firmware.
    • Drives without ATA Secure Erase will need to be erased externally. Select External and choose Nwipe. Run the DoD Short command (3 wipes+drive blanking).
    • If your drive has a buggy ATA Secure Erase implementation, choose External and erase the drive with Nwipe. SSDs should only be erased with the Secure Erase command.
    • For NVMe SSDs, the best option is to use NVMe Secure Erase.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
89,943 평판
안내서 52개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 17
30일 전: 55
전체 시간: 1,922
