주요 콘텐츠로 건너뛰기
DigiLand DL701Q Back Case Replacement
필요한 것
  1. DigiLand DL701Q Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 1개 DigiLand DL701Q Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 2개 DigiLand DL701Q Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: 2 단계, 이미지 3개 중 1개 DigiLand DL701Q Back Case Replacement: 2 단계, 이미지 3개 중 2개 DigiLand DL701Q Back Case Replacement: 2 단계, 이미지 3개 중 3개
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Mysona
회원 가입일: 03/21/16
1,135 평판
안내서 7개를 작성함
Clemson, Team 6-1, Benson Spring 2016 Clemson, Team 6-1, Benson Spring 2016 회원
CLEM-BENSON-S16S6G1
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 1,031
