주요 콘텐츠로 건너뛰기
DigiLand DL8006 Speaker Replacement
필요한 것
  1. DigiLand DL8006 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: 2 단계, 이미지 1/2 DigiLand DL8006 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: 3 단계, 이미지 1/2 DigiLand DL8006 Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: 4 단계, 이미지 1/3 DigiLand DL8006 Speaker Replacement: 4 단계, 이미지 2/3 DigiLand DL8006 Speaker Replacement: 4 단계, 이미지 3/3
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: 6 단계, 이미지 1/2 DigiLand DL8006 Speaker Replacement: 6 단계, 이미지 2/2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
결론
Alec Trela
회원 가입일: 10/30/19
327 평판
안내서 2개 작성하였습니다
University of Memphis, Team S2-G5, Kim Fall 2019 University of Memphis, Team S2-G5, Kim Fall 2019 회원
UM-KIM-F19S2G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 133
