주요 콘텐츠로 건너뛰기
DigiLand DL801W Microphone Replacement
필요한 것
  1. DigiLand DL801W Microphone Replacement, Microphone: 1 단계, 이미지 1/1
    • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Microphone Replacement: 2 단계, 이미지 1/1
    • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
    • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Travis Mangum
회원 가입일: 09/17/15
572 평판
안내서 4개 작성하였습니다
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 335
