주요 콘텐츠로 건너뛰기
DigiLand DL801W Speaker Replacement
필요한 것
  1. DigiLand DL801W Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the two JIS #000 screws that hold the speaker bracket in place. Be sure to place the screws in a safe place to avoid losing them.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective speaker.
    • Complete removal of the speaker from the motherboard is not necessary. It is just recommended that the bracket be removed to allow more room for battery removal.
결론
Travis Mangum
회원 가입일: 09/17/15
572 평판
안내서 4개 작성하였습니다
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 232
