주요 콘텐츠로 건너뛰기
Digiland 10.1'' DL1016 Motherboard Replacement
필요한 것
  1. Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Remove Backing: 1 단계, 이미지 2개 중 1개 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Remove Backing: 1 단계, 이미지 2개 중 2개
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Digiland 10.1'' DL1016 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: 3 단계, 이미지 3개 중 1개 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: 3 단계, 이미지 3개 중 2개 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: 3 단계, 이미지 3개 중 3개
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. 주의: 4 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 4 단계, 이미지 2개 중 1개 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 4 단계, 이미지 2개 중 2개
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  5. Digiland 10.1'' DL1016 Motherboard Replacement, Power Button: 5 단계, 이미지 1개 중 1개
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Digiland 10.1'' DL1016 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Motherboard Replacement, Motherboard: 7 단계, 이미지 1개 중 1개
    • Once you have followed all steps simply replace the motherboard to fix your RAM
결론
To reassemble your device, follow these instructions in reverse order. When following the Prerequisite Guide for Replacing the Power Button ONLY go to step 7.
작성자
2다른 기여자 명과 함께
Virginia Tapia
회원 가입일: 08/26/19
395 평판
안내서 3개를 작성함
Gateway, Team S1-G2, Saknee Fall 2019 Gateway, Team S1-G2, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 664
