주요 콘텐츠로 건너뛰기
Digitac Jazz Ultratab C725 Speaker Replacement
필요한 것
  1. Digitac Jazz Ultratab C725 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Digitac Jazz Ultratab C725 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Digitac Jazz Ultratab C725 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
    • Using the Phillips #00 Screwdriver, remove all 4 screws.
    • Remove the screws with the least amount of force possible to avoid any damage to the threads. If thread damage occurs, screw removal will be much more difficult or may even become impossible.
  2. Digitac Jazz Ultratab C725 Speaker Replacement: 2 단계, 이미지 1/3 Digitac Jazz Ultratab C725 Speaker Replacement: 2 단계, 이미지 2/3 Digitac Jazz Ultratab C725 Speaker Replacement: 2 단계, 이미지 3/3
    • Flip your device so that the long side without the buttons is facing you.
    • Insert the Plastic Opening Tool between the silver back plate and the screen about 1 inch from corner of the device on either side.
    • Jimmy the Plastic Opening Tool until the screen unsnaps from the back plate.
    • Work your way down the edge of the device, popping out all locations where the screen snaps into the silver back plate.
    • Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
    • Once the screen is loose, pull it towards you then lift it off to prevent damage to the buttons on the other side of the device.
  3. Digitac Jazz Ultratab C725 Speaker Replacement: 3 단계, 이미지 1/2 Digitac Jazz Ultratab C725 Speaker Replacement: 3 단계, 이미지 2/2
    • Use a soldering iron to melt the solder that connects the speaker to the motherboard.
    • Pull the wires out.
  4. Digitac Jazz Ultratab C725 Speaker Replacement: 4 단계, 이미지 1/3 Digitac Jazz Ultratab C725 Speaker Replacement: 4 단계, 이미지 2/3 Digitac Jazz Ultratab C725 Speaker Replacement: 4 단계, 이미지 3/3
    • Insert the plastic opening tool in the gap between the speaker and the bracket that holds it.
    • Pry the speaker out of the bracket.
결론
Seth York
회원 가입일: 01/20/15
355 평판
안내서 3개 작성하였습니다
USF Tampa, Team 11-6, Blackwell Winter 2015 USF Tampa, Team 11-6, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G6
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 95
