소개
The following guide will show how to remove the volume control and screen lock buttons from the Digitac Jazz Ultratab C725 for replacement.
필요한 것
Locate the four 3.5 mm Phillips screws holding the silver back plate and the screen together. There are two screws on the top and two screws on the bottom.
Using the Phillips #00 Screwdriver, remove all four screws.
Flip your device so that the long side without the buttons faces you.
Insert the Plastic Opening Tool between the silver back plate and the screen about one inch from the corner of the device on either side.
Using the Plastic Opening Tool, pry open the screen until it unsnaps from the back plate.
Work your way down the edge of the device, unsnapping all locations where the screen meets the silver back plate.
Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
Using a pair of tweezers, poke the square plastic piece between each of the buttons that connect them together. Each button has a plastic piece between their gaps.
While poking the square piece in, simultaneously push it upward to release it.
After releasing the first one, use the pair of tweezers, and do the same with the second one. This should free all buttons from the device.
Once the buttons are free, use the set of tweezers to grab the buttons and pull them out.
