주요 콘텐츠로 건너뛰기
Digital AV Mixer WJ-AVE5 Disassembly
필요한 것
  1. Digital AV Mixer WJ-AVE5 Disassembly, View From Above: 1 단계, 이미지 1/1
    • This is a Digital AV Mixer (Model WJ-AVE5) and we'll be covering the steps required to remove the top-board and controls.
  2. Digital AV Mixer WJ-AVE5 Disassembly, The Knob: 2 단계, 이미지 1/1
    • Unscrew the stick extension by turning it left. If you're running into resistance try holding the shaft of the stick, during previous service this extension may have had Loctite applied to stock it from loosening.
  3. Digital AV Mixer WJ-AVE5 Disassembly, View From Below: 3 단계, 이미지 1/3 Digital AV Mixer WJ-AVE5 Disassembly, View From Below: 3 단계, 이미지 2/3 Digital AV Mixer WJ-AVE5 Disassembly, View From Below: 3 단계, 이미지 3/3
    • This is the bottom of your Digital Mixer. There are Seventeen (17) screws that need to move forward.
  4. Digital AV Mixer WJ-AVE5 Disassembly, The Pizza Box Open: 4 단계, 이미지 1/2 Digital AV Mixer WJ-AVE5 Disassembly, The Pizza Box Open: 4 단계, 이미지 2/2
    • Now the top-board should pivot up like a pizza-box allowing access to both the solder side of the top-board and the EMI Shielding for both the Primary Power Board and the Primary Control Board.
  5. Digital AV Mixer WJ-AVE5 Disassembly, Solder-Side of Top-Board: 5 단계, 이미지 1/1
    • Shot of the solder-side of the top-board for reference on connector locations, cable routing, and component reference.
  6. Digital AV Mixer WJ-AVE5 Disassembly: 6 단계, 이미지 1/1
    • Shot of the bottom-board for reference on connector locations, cable routing, and component reference.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bridgetown Electronics Repair
회원 가입일: 01/26/17
739 평판
안내서 3개 작성하였습니다
Bridgetown Repair Bridgetown Repair 회원
Business
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 648
