주요 콘텐츠로 건너뛰기
Digital Calipers Battery Replacement
필요한 것
  1. Digital Calipers Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Digital Calipers Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Digital Calipers Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use the pad of your thumb to slide the battery cover away from the display.
    • Remove the battery cover.
  2. Digital Calipers Battery Replacement, Remove the battery: 2 단계, 이미지 2개 중 1개 Digital Calipers Battery Replacement, Remove the battery: 2 단계, 이미지 2개 중 2개
    • Remove the battery.
  3. Digital Calipers Battery Replacement, Install a new battery: 3 단계, 이미지 3개 중 1개 Digital Calipers Battery Replacement, Install a new battery: 3 단계, 이미지 3개 중 2개 Digital Calipers Battery Replacement, Install a new battery: 3 단계, 이미지 3개 중 3개
    • Insert the new battery at a downward angle into its recess, positive (+) side facing up.
    • A small piece of angled metal secures the battery in its recess.
    • Press down on the battery so it sits flush in the recess.
    • The display should turn on. If it doesn't, even after pressing the on/off button, the battery may be upside down or already dead.
  4. Digital Calipers Battery Replacement, Reinstall the battery cover: 4 단계, 이미지 3개 중 1개 Digital Calipers Battery Replacement, Reinstall the battery cover: 4 단계, 이미지 3개 중 2개 Digital Calipers Battery Replacement, Reinstall the battery cover: 4 단계, 이미지 3개 중 3개
    • Press the outer edge of the battery down with the cover and slide the cover into place.
    • If this feels difficult, the battery may not be seated correctly. Reinsert it and try again.
결론
For more information on how to use digital calipers, follow this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
For other general electronics skills guides, click here.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
153,496 평판
안내서 1,024개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,735개를 작성함
1가이드 댓글
hi i am looking to replace my battery cover for my vernier ams32 any ideas
Robert Wales - 답글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 206
지난 30일: 882
전체 시간: 30,312
