소개
This guide is on how to replace the soldering wire on a Taylor Digital Scale Model #7403. There is a loose connection within the scale that allows the scale to turn on but not function as it should. The replacement of this soldering wire is needed so that the scale can operate properly. You will need some knowledge of soldering.
필요한 것
If your scale turns on and works properly but once you use it then it turns off, then it is likely there is a loose connection that needs to be replaced.
다른 한 분이 해당 안내서를 완성하였습니다.
