주요 콘텐츠로 건너뛰기
Digital2 7" Tablet D2-713G GN Speaker Replacement
필요한 것
  1. Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 1 단계, 이미지 1/3 Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 1 단계, 이미지 2/3 Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 1 단계, 이미지 3/3
    • With the appropriate tools on hand, you want to look for the charging port.
    • Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border.
    • Now continue to pry the case with the same technique all around.
    • After prying all around the device, you will be able to separate the back cover from the display , which holds all the components.
  2. Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 2 단계, 이미지 1/3 Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 2 단계, 이미지 2/3 Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 2 단계, 이미지 3/3
    • Once you have opened the case completely, you will be able to see the speaker.
    • With one hand hold the device down to the table and with the other hand remove the speaker from where it sits.
    • Follow the black and red wires to the circuit board.
    • The wires will have to be removed with a soldering tool.
    • This process is also needed when installing the new speaker.
결론
Miguel A Rodriguez
회원 가입일: 10/25/14
590 평판
안내서 4개 작성하였습니다
Gateway, Team 1-6, Johnson Fall 2014 Gateway, Team 1-6, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G6
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 269
