주요 콘텐츠로 건너뛰기
Digital2 D2-861G Camera Replacement
필요한 것
  1. Digital2 D2-861G Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen
    • Flip your device over so back panel is facing upwards.
  2. Digital2 D2-861G Camera Replacement: 2 단계, 이미지 1/1
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card.
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Camera Replacement: 3 단계, 이미지 1/1
    • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
  4. Digital2 D2-861G Camera Replacement: 4 단계, 이미지 1/2 Digital2 D2-861G Camera Replacement: 4 단계, 이미지 2/2
    • Locate and unplug the flat-top connector from the motherboard..
    • To unplug the connector go under it with either side of the spudger and lift up.
  5. Digital2 D2-861G Camera Replacement: 5 단계, 이미지 1/2 Digital2 D2-861G Camera Replacement: 5 단계, 이미지 2/2
    • Avoid pulling the gold connector as it can be damaged and/or broken.
    • To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eduardo Duran
회원 가입일: 09/29/16
600 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 135
