소개
This repair is necessary if the motherboard of the Digital2 D2-912 becomes defective at any point. Repairing the motherboard will help overall performance, as it establishes a connection from the hardware of the device to the processor. Special skills are not required to complete this repair. This manual highlights the necessary steps and tools for successful completion.
필요한 것
Wedge the opening tool in the space between the back and the front of the tablet.
Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
When the back of the tablet is mostly detached from the front, carefully pull it away completely.
이 단계에 사용된 도구:Desoldering Pump$3.99
Remove the wires shown in the image, using a soldering iron and solder sucker.
다른 2명이 해당 안내서를 완성하였습니다.
