주요 콘텐츠로 건너뛰기
Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement
필요한 것
  1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, External Cover: 1 단계, 이미지 1/1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 2 단계, 이미지 1/2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 3 단계, 이미지 1/2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, Front/Rear Facing Camera: 4 단계, 이미지 1/1
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  5. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 5 단계, 이미지 1/2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  6. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 6 단계, 이미지 1/1
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  7. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 7 단계, 이미지 1/1
    • Finally remove the cameras.
결론
David DeMeritt
회원 가입일: 03/08/16
637 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 102
