주요 콘텐츠로 건너뛰기
Digital2 Platinum Pad 9 Volume Buttons Replacement
필요한 것
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: 1 단계, 이미지 1/1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: 2 단계, 이미지 1/2 Digital2 Platinum Pad 9 Volume Buttons Replacement: 2 단계, 이미지 2/2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: 3 단계, 이미지 1/2 Digital2 Platinum Pad 9 Volume Buttons Replacement: 3 단계, 이미지 2/2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: 4 단계, 이미지 1/1
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: 5 단계, 이미지 1/1
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: 6 단계, 이미지 1/1
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: 7 단계, 이미지 1/1
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: 8 단계, 이미지 1/2 Digital2 Platinum Pad 9 Volume Buttons Replacement: 8 단계, 이미지 2/2
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
결론
David DeMeritt
회원 가입일: 03/08/16
637 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 93
