소개
This guide will help users to replace buttons on top of the Digitech XC-5206 speaker system, including: volume controls, power button, and Bluetooth button. Please refer to troubleshooting page before beginning replacement guide steps.
부품
부품은 필요하지 않습니다.
  1. Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off. You may need to use extra force.
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion. Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face. OR grab ahold of the silver tab to pull the speaker face out. This may require force.
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  5. Remove circuit board by pulling straight upwards out of slot. Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom. Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
결론
Kassidy Wyckoff
회원 가입일: 2018년 10월 02일
655 평판
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 58
