주요 콘텐츠로 건너뛰기
Digitech XC- 5206 Dual Speaker Replacement
필요한 것
  1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: 1 단계, 이미지 1/2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: 1 단계, 이미지 2/2
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Dual Speaker Replacement: 2 단계, 이미지 1/3 Digitech XC- 5206 Dual Speaker Replacement: 2 단계, 이미지 2/3 Digitech XC- 5206 Dual Speaker Replacement: 2 단계, 이미지 3/3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Dual Speaker Replacement: 3 단계, 이미지 1/2 Digitech XC- 5206 Dual Speaker Replacement: 3 단계, 이미지 2/2
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  4. Digitech XC- 5206 Dual Speaker Replacement: 4 단계, 이미지 1/2 Digitech XC- 5206 Dual Speaker Replacement: 4 단계, 이미지 2/2
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kassidy Wyckoff
회원 가입일: 10/02/18
655 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 224
