주요 콘텐츠로 건너뛰기
Direct-Drive Cleaner Head Brush Bar Replacement
필요한 것
  1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: 1 단계, 이미지 1/2 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: 1 단계, 이미지 2/2
    • First, make sure the device is unplugged and detached from the wand
    • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
    • Padlocks
  2. Direct-Drive Cleaner Head Brush Bar Replacement: 2 단계, 이미지 1/1
    • Slide the brush bar away from the cleaner head
결론
다른 6명이 해당 안내서를 완성하였습니다.
Saba G Arefaine
회원 가입일: 10/18/17
272 평판
안내서 1개 작성함
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 회원
UWT-ROSE-F17S1G5
4 회원들
안내서 15개 작성하였습니다
댓글 2개
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - 답글
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 46
30일 전: 228
전체 시간: 35,354
