주요 콘텐츠로 건너뛰기
Direct-Drive Turntable Cartridge and Needle Replacement
필요한 것
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: 1 단계, 이미지 1개 중 1개
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: 2 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 2 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement: 2 단계, 이미지 3개 중 3개
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: 3 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 3 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: 4 단계, 이미지 2개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: 5 단계, 이미지 2개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: 6 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 6 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement: 6 단계, 이미지 3개 중 3개
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: 7 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 7 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement: 7 단계, 이미지 3개 중 3개
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: 8 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement: 8 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement: 8 단계, 이미지 3개 중 3개
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: 9 단계, 이미지 1개 중 1개
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
  10. Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: 10 단계, 이미지 3개 중 1개 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: 10 단계, 이미지 3개 중 2개 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: 10 단계, 이미지 3개 중 3개
    • For good sound the needle has to fit parallel into the record groove. Othrewise the sound isn't leveled between left and right channel.
    • Therefore templates are available to buy or to print. They got orthogonal lines on the area where the needle is setting in and where it is setting off.
    • The needle should be parallel to the lines on the template at R120,9 mm. If not, the screws shown in step 3 can be loosened and the cartridge can be adjusted. After adjusting tight the screws up again.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dylan Udhesister
회원 가입일: 09/18/20
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 1,283
