주요 콘텐츠로 건너뛰기
Dis/assembling Eye/Pupil Camera Housing
필요한 것
  1. Dis/assembling Eye/Pupil Camera Housing, Dis/assembling Eye/Pupil Camera Housing: 1 단계, 이미지 1/1
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Dis/assembling Eye/Pupil Camera Housing: 2 단계, 이미지 1/1
    • Remove 4 screws.
  3. Dis/assembling Eye/Pupil Camera Housing: 3 단계, 이미지 1/1
    • Remove cover to get to the PCB underneath
  4. Dis/assembling Eye/Pupil Camera Housing: 4 단계, 이미지 1/1
    • Remove two screws on the PCB.
  5. Dis/assembling Eye/Pupil Camera Housing: 5 단계, 이미지 1/1
    • Remove PCB from the base plastic piece.
  6. Dis/assembling Eye/Pupil Camera Housing: 6 단계, 이미지 1/1
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Dis/assembling Eye/Pupil Camera Housing: 7 단계, 이미지 1/1
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Dis/assembling Eye/Pupil Camera Housing: 8 단계, 이미지 1/1
    • Completed assembly of the eye camera.
  9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: 9 단계, 이미지 1/1
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Dis/assembling Eye/Pupil Camera Housing: 10 단계, 이미지 1/1
    • Remove the black frame on the front of the pupil camera.
  11. Dis/assembling Eye/Pupil Camera Housing: 11 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 11 단계, 이미지 2/2
    • Once frame is taken off the front, two screws need to be removed.
  12. Dis/assembling Eye/Pupil Camera Housing: 12 단계, 이미지 1/1
    • One screw removed from the back.
  13. Dis/assembling Eye/Pupil Camera Housing: 13 단계, 이미지 1/1
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  14. Dis/assembling Eye/Pupil Camera Housing: 14 단계, 이미지 1/1
    • Pull off bottom stand until it breaks off.
  15. Dis/assembling Eye/Pupil Camera Housing: 15 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 15 단계, 이미지 2/2
    • Remove rubber/plastic piece from the bottom
  16. Dis/assembling Eye/Pupil Camera Housing: 16 단계, 이미지 1/1
    • Remove four screws from under the plastic tape (removed from last step).
  17. Dis/assembling Eye/Pupil Camera Housing: 17 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 17 단계, 이미지 2/2
    • Bottom pops off
  18. Dis/assembling Eye/Pupil Camera Housing: 18 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 18 단계, 이미지 2/2
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  19. Dis/assembling Eye/Pupil Camera Housing: 19 단계, 이미지 1/1
    • Take out PCB from the plastic housing.
  20. Dis/assembling Eye/Pupil Camera Housing: 20 단계, 이미지 1/3 Dis/assembling Eye/Pupil Camera Housing: 20 단계, 이미지 2/3 Dis/assembling Eye/Pupil Camera Housing: 20 단계, 이미지 3/3
    • Remove the rest of the black plastic housing.
  21. Dis/assembling Eye/Pupil Camera Housing: 21 단계, 이미지 1/1
    • Black plastic housing removed
  22. Dis/assembling Eye/Pupil Camera Housing: 22 단계, 이미지 1/3 Dis/assembling Eye/Pupil Camera Housing: 22 단계, 이미지 2/3 Dis/assembling Eye/Pupil Camera Housing: 22 단계, 이미지 3/3
    • Continue removing the black plastic housing surrounding the inner PCB.
  23. Dis/assembling Eye/Pupil Camera Housing: 23 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 23 단계, 이미지 2/2
    • PCB removed from the black plastic housing.
  24. Dis/assembling Eye/Pupil Camera Housing: 24 단계, 이미지 1/1
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  25. Dis/assembling Eye/Pupil Camera Housing: 25 단계, 이미지 1/1
    • Unscrew the lens
  26. Dis/assembling Eye/Pupil Camera Housing: 26 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 26 단계, 이미지 2/2
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  27. Dis/assembling Eye/Pupil Camera Housing: 27 단계, 이미지 1/3 Dis/assembling Eye/Pupil Camera Housing: 27 단계, 이미지 2/3 Dis/assembling Eye/Pupil Camera Housing: 27 단계, 이미지 3/3
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  28. Dis/assembling Eye/Pupil Camera Housing: 28 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 28 단계, 이미지 2/2
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  29. Dis/assembling Eye/Pupil Camera Housing: 29 단계, 이미지 1/1
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  30. Dis/assembling Eye/Pupil Camera Housing: 30 단계, 이미지 1/3 Dis/assembling Eye/Pupil Camera Housing: 30 단계, 이미지 2/3 Dis/assembling Eye/Pupil Camera Housing: 30 단계, 이미지 3/3
    • Insert PCB into 3d-printed frame.
  31. Dis/assembling Eye/Pupil Camera Housing: 31 단계, 이미지 1/2 Dis/assembling Eye/Pupil Camera Housing: 31 단계, 이미지 2/2
    • Completed assembly.
    • Sugru used for nose/head rest
결론
다른 2명이 해당 안내서를 완성하였습니다.
Silas
회원 가입일: 11/25/13
318 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 650
