주요 콘텐츠로 건너뛰기
Disabling DualShock 4's Blue LED
필요한 것
  1. Disabling DualShock 4's Blue LED, Disabling DualShock 4's Blue LED: 1 단계, 이미지 1개 중 1개
    • Remove the four Phillips #00 screws from the back of the controller.
  2. Disabling DualShock 4's Blue LED: 2 단계, 이미지 1개 중 1개
    • Remove the bottom half of the controller while monitoring the triggers and springs within.
  3. Disabling DualShock 4's Blue LED: 3 단계, 이미지 1개 중 1개
    • Pull the ribbon cable out of the LED/USB connecter assembly in the center of the controller.
  4. Disabling DualShock 4's Blue LED: 4 단계, 이미지 2개 중 1개 Disabling DualShock 4's Blue LED: 4 단계, 이미지 2개 중 2개
    • Place a thin piece of paper in front of the last 2 pins (counting from left to right).
    • The paper will prevent the motherboard from completing the circuit that enables the blue LED.
  5. Disabling DualShock 4's Blue LED: 5 단계, 이미지 2개 중 1개 Disabling DualShock 4's Blue LED: 5 단계, 이미지 2개 중 2개
    • Don't twist the ribbon cable when inserting it.
    • Insert back ribbon cable with piece of thin paper already inserted.
    • Connect the bottom half of the DualShock 4 controller together.
    • Rescrew 4 Phillips screws on the back of the controller.
결론
All you have to do now - is embrace the darkness; don't forget to screw the thing back together though :)
다른 12명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Darie H
회원 가입일: 11/20/12
4,644 평판
안내서 5개를 작성함
16가이드 댓글
You are using the word "loose" incorrectly.
Loose is an adjective, the opposite of tight or contained.
Lose is a verb that means to suffer the loss of, to miss.
Matt Ferguson - 답글
*crrrrcth*...."we've got a 10-O-3 in progress, disturbing the English language, requesting grammar assistance"....*crrrrctch*
*crrrrctch*...."roger dispatch, Ferguson en route"....*crrrrtch*
Fuzy Munky -
Yeah, some people actually prefer their guides to look as professional as possible. Correcting someone’s grammar in a guide is meant to help them properly establish their brand. If you prefer to write a guide, Fuzy, with completely broken English (or whichever language you prefer) then you’re free to do so. I’m quite sure many people would second-guess the information within if the grammar is terrible. It’s all about appearance, professionalism, and personal brand.
Robert -
Thanks - now I realised it too :))
Darie H - 답글
This $@$* &&^& my &&^&^$^ controller up and now I'm mad fickle this $@$*
Mario Avila - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 117
전체 시간: 32,699
