주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Flipper Zero 수리는 자사의 서비스 설명서를 사용하세요.
  1. Flipper Zero Teardown, Caution: 1 단계, 이미지 1개 중 1개
    • Do not use alcohol or alcohol containing cleaners, tissues, wipes, or sanitizers on the acrylic window! It can permanently damage it.
    • The top shell, the IR cover and the acrylic window are one solid part and can't be disassembled. (They pop out with a bit of force but wont go back in as well without some sort of glue)
    • The Flipper Zero only uses two types of screws:
    • Long screw size is M1.7x8
    • Short screw size is M1.7x4
  2. Flipper Zero Teardown, Remove the microSD card: 2 단계, 이미지 1개 중 1개
    • Eject the microSD card (if present) by pressing it with your fingernail.
  3. Flipper Zero Teardown, Remove the screws: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
  4. Flipper Zero Teardown, Open the back cover: 4 단계, 이미지 3개 중 1개 Flipper Zero Teardown, Open the back cover: 4 단계, 이미지 3개 중 2개 Flipper Zero Teardown, Open the back cover: 4 단계, 이미지 3개 중 3개
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  5. Flipper Zero Teardown, Lift the NFC antenna: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
  6. Flipper Zero Teardown, Pull out the NFC antenna: 6 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Pull out the NFC antenna: 6 단계, 이미지 2개 중 2개
    • Gently pull out the rest of the board.
  7. Flipper Zero Teardown, Unscrew the chassis: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
  8. Flipper Zero Teardown, Seperate the chassis from the top cover: 8 단계, 이미지 1개 중 1개
    • Take the chassis out of the case.
  9. Flipper Zero Teardown, Disconnect the battery: 9 단계, 이미지 1개 중 1개
    • Disconnect the battery by prying the connector with a plastic pry tool and pulling it out.
    • Do not use a metal screwdriver when prying out battery connectors, if you do it may short the battery terminals and cause damage to the battery.
  10. Flipper Zero Teardown, Disconnect the ribbon cables: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
  11. Flipper Zero Teardown, Disconnect the ribbon cables: 11 단계, 이미지 1개 중 1개
    • Once the connectors are unlocked, carefully pull out the ribbon cables.
  12. Flipper Zero Teardown, Unscrew the iButton board: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
  13. Flipper Zero Teardown, Remove the iButton board: 13 단계, 이미지 1개 중 1개
    • Once the screw is removed, carefully remove the iButton board.
  14. Flipper Zero Teardown, Remove the cable from the iButton board: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    • To disconnect the flat cable from the iButton board, use a flat screwdriver to carefully release the lock by pulling the latch up, then pulling gently on the ribbon cable.
  15. Flipper Zero Teardown, Remove the cable from the iButton board: 15 단계, 이미지 1개 중 1개
    • Once the connector is unlocked, gently pull the cable out of the connector.
  16. Flipper Zero Teardown, Release the battery chassis: 16 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Release the battery chassis: 16 단계, 이미지 2개 중 2개
    • To release the battery chassis, gently rock it back and forth while pulling the two parts apart.
  17. Flipper Zero Teardown, Remove the NFC RFID board: 17 단계, 이미지 1개 중 1개
    • To remove the NFC RFID board, release it from the latches in the sequence shown.
  18. Flipper Zero Teardown, Remove the NFC RFID board: 18 단계, 이미지 1개 중 1개
    • Release the board from the latches by pressing on the edge of the chassis near the specific latch in the specified sequence.
  19. Flipper Zero Teardown, Remove the vibration motor: 19 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Remove the vibration motor: 19 단계, 이미지 2개 중 2개
    • Take out the vibration motor.
  20. Flipper Zero Teardown, Unscrew the lace mount: 20 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  21. Flipper Zero Teardown, Remove the lace mount: 21 단계, 이미지 1개 중 1개
    • Remove the lace mount from the chassis.
  22. Flipper Zero Teardown, Remove the battery: 22 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  23. Flipper Zero Teardown, Remove the battery: 23 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Remove the battery: 23 단계, 이미지 2개 중 2개
    • Remove the battery from the chassis.
  24. Flipper Zero Teardown, Remove the ribbon cable: 24 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a plastic pick to lift the latch up to unlock the connector.
  25. Flipper Zero Teardown, Remove the ribbon cable: 25 단계, 이미지 1개 중 1개
    • Pull the flat cable out.
  26. Flipper Zero Teardown, Unscrew the the button chassis: 26 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  27. Flipper Zero Teardown, Separate the button chassis: 27 단계, 이미지 1개 중 1개
    • To disconnect the button chassis and the board, press the latch on the side shown below.
  28. Flipper Zero Teardown, Remove the button chassis: 28 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Remove the button chassis: 28 단계, 이미지 2개 중 2개
    • Remove the button chassis.
  29. Flipper Zero Teardown, Disconnect the screen: 29 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock.
  30. Flipper Zero Teardown, Disconnect the screen: 30 단계, 이미지 1개 중 1개
    • Remove the cable from the board.
  31. Flipper Zero Teardown, Desolder the screen: 31 단계, 이미지 1개 중 1개
    • To remove the screen you need to desolder two contacts.
    • Be careful during this step not to accidentally melt or desolder other nearby components.
  32. Flipper Zero Teardown, Remove the buttons: 32 단계, 이미지 1개 중 1개
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad)
  33. Flipper Zero Teardown, Remove the buttons: 33 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Release the latches with a flat screwdriver. You need to be careful with the springs under the buttons.
  34. Flipper Zero Teardown, Remove the light guide: 34 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
  35. Flipper Zero Teardown, Remove the light guide: 35 단계, 이미지 2개 중 1개 Flipper Zero Teardown, Remove the light guide: 35 단계, 이미지 2개 중 2개
    • Pull the light guide out from the inside of the chassis.
  36. Flipper Zero Teardown, Finish: 36 단계, 이미지 1개 중 1개
    • Here you can see all the parts laid out together.
작성자
8다른 기여자 명과 함께
Flipper Devices
회원 가입일: 06/29/22
705 평판
안내서 1개를 작성함
15가이드 댓글
I'd say, that long screws requires PH1 screwdriver.
Evge Key - 답글
Agree with Evge, when I read "PH0" I picked mine but they wouldn't quite fit. I had to use a PH1 (1.2 to be exact, according to toolset casing) to be able to unscrew the chasis and get to the battery (I had to only remove and plug back the battery cable to fix my problem)
João Ciocca - 답글
Careful with those screws. They are not great quality and strip easily.
andy cooper - 답글
Yeah, I have run into the same issue. The screw securing my IR/iButton board sheered in half! I cant remove the bottom part since its flush with the socket, but the board seems to be alright without it and is still in place since the chassis supports it. I still need to find a way to get it out :)
SkidFace -
Do you know what kind of these screws are?
Gugo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 156
지난 30일: 759
전체 시간: 56,462
