소개
Disassembly
1. Flip toaster over.
2. Locate four phillips screws on the bottom of the toaster.
3. Loosen and remove.
4. Sides will pop out once screws are removed.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
I Disassembled, cleaned and put it back together. However the purpose of the exercise was to fix the browning feature or timing issue. the little plastic bit that goes from the browning turn knob does not function. So the push knob does not stay down. This results in having to hold the push knob down till the toast is done to my satisfaction. The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
