주요 콘텐츠로 건너뛰기
Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body
필요한 것
  1. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body, Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: 1 단계, 이미지 1/1
    • 1. Flip toaster over.
  2. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: 2 단계, 이미지 1/1
    • 2. Locate four phillips screws on the bottom of the toaster.
  3. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: 3 단계, 이미지 1/1
    • 3. Loosen and remove using a Phillips head screwdriver
  4. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: 4 단계, 이미지 1/1
    • 4. Sides will pop out once screws are removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Carlos
회원 가입일: 07/23/13
113 평판
안내서 1개 작성함
UC Santa Barbara, Team 2-5, Bradley Summer 2013 UC Santa Barbara, Team 2-5, Bradley Summer 2013 회원
UCSB-BRADLEY-R13S2G5
6 회원들
안내서 1개 작성하였습니다
댓글 3개
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - 답글
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - 답글
To slide down the toast, the lever does not go down completely, leaving the top of bread exposed. Is there a way to adjust the depth the toast goes down? If so, could you send me instructions. Thank you
Christina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 21
전체 시간: 1,842
