이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grip the right side of the console and pull up towards the passenger seat to remove it.
Locate the two bolts under the air conditioning controls at the bottom of the face plate.
Loosen these two bolts with a basic socket wrench suited for 7mm bolts.
Wedge a spudger or plastic opening tool (in place of the screwdriver shown) under the top of the face plate.
Apply pressure until the corners "pop" out of place.
Inspect the interior of the center console for damaged wires or other faulty components.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 4개
Were can I get that faceplate connector and the connectors for the sterio...I have a 2010 v6 mustang
I found a replacement but need wire configuration for the 4 wires can anyone help ?
Try using the correct tool to remove panels...
The screwdriver is not required. Nor is any other tool at that point. GENTLY pull from the tabs where you removed the screws.
The faceplate will begin to loosen from the bottom up. After pulling out a few inches, push back inward about a half of an inch. This has the effect of a teeter/totter on the remaining top wedge pins. Now grasp the two knobs on the bottom of the panel (fan and temp) and loosen first the left side and then the right side. No real force required at any time and practically falls out. NO SCARS on the trim.
cheers,
dbw -
