주요 콘텐츠로 건너뛰기
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
필요한 것
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: 1 단계, 이미지 1/2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: 1 단계, 이미지 2/2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 2 단계, 이미지 1/3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 2 단계, 이미지 2/3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 2 단계, 이미지 3/3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 3 단계, 이미지 1/1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Efe Guldogan
회원 가입일: 08/26/15
860 평판
안내서 4개 작성하였습니다
USF Tampa, Team 14-23, Meier Fall 2015 USF Tampa, Team 14-23, Meier Fall 2015 회원
USFT-MEIER-F15S14G23
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 23
전체 시간: 13,695
