주요 콘텐츠로 건너뛰기
Disassembling Acer Iconia A1-830 Back Panel
필요한 것
  1. Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 1/2 Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 2/2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Disassembling Acer Iconia A1-830 Back Panel: 2 단계, 이미지 1/2 Disassembling Acer Iconia A1-830 Back Panel: 2 단계, 이미지 2/2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Matt Champagne
회원 가입일: 10/20/15
458 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G6
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Hi iv got an acer icon is one 10.iv done a factory reset ,but it hasent come back ,and it turns on but I can't stop it talking ,volume won't turn down and ,when I checked the volume button it says it turn off .the tablet won't do anything .can you tell me if it's worth repairing and how much if possible. Thank you Teresa spry
Teresa Spry - 답글
Can the back of the tablet be completely removed, so i can look at the micro USB port, to see if that is what is not letting the tablet charge !! Without not knowing what I’m doing and messing it up!!
andre_chatel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 6,070
