주요 콘텐츠로 건너뛰기
Disassembling Apple AirPort Extreme Base Station Model A1034
필요한 것
  1. Disassembling Apple AirPort Extreme Base Station Model A1034, Disassembling Apple AirPort Extreme Base Station Model A1034: 1 단계, 이미지 1/1
    • Remove the three 5mm T7 Torx screws from the back panel.
  2. Disassembling Apple AirPort Extreme Base Station Model A1034: 2 단계, 이미지 1/1
    • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
  3. Disassembling Apple AirPort Extreme Base Station Model A1034: 3 단계, 이미지 1/1
    • Separate the bottom and top casings.
  4. Disassembling Apple AirPort Extreme Base Station Model A1034: 4 단계, 이미지 1/2 Disassembling Apple AirPort Extreme Base Station Model A1034: 4 단계, 이미지 2/2
    • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
    • Remove the four screws from the metal casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Michael Garcia
회원 가입일: 10/12/11
411 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 회원
CPSU-REGAN-F11S17G15
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
Whoa, who’d have thought there was a hidden 5mm phillips under the serial number that does the trick? I’ve had this little beauty hanging around for decades, and my six year old started using it as a flying saucer with his lego creations, and it took me three months of pandemic before I picked up my screwdrivers and tried to take it apart so that he could really use it. For now it’s just empty, and he closes some figures in it with a rubber band and flies it around. Someday I’ll get that dremel i’ve wanted and make him some sort of hatch and latch for it, maybe add some lego baseplate bits to it or something, it can join the rebel alliance for reals.
bitfool - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 24
전체 시간: 2,733
