이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide shows you how to remove the cover of an Apple IIc computer. All you need to perform this repair is a screwdriver and something to help open the casing. This is a precursor to any other repair you may want to do on this device and also allows you to get a good look at its internal workings.
필요한 것
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 3개
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - 답글
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
