주요 콘텐츠로 건너뛰기
Disassembling Asus Eee PC 1000HE Lower Assembly
필요한 것
  1. Disassembling Asus Eee PC 1000HE Lower Assembly, Lower Assembly: 1 단계, 이미지 1/1
    • Turn off the power and remove the battery before working on your Eee PC
    • Start by removing the keyboard
    • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
    • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
    • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
    • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
  2. Disassembling Asus Eee PC 1000HE Lower Assembly: 2 단계, 이미지 1/2 Disassembling Asus Eee PC 1000HE Lower Assembly: 2 단계, 이미지 2/2
    • 7 screws hold the front plate to the motherboard, as well as the ones on the rear of the PC.
    • Before taking off the case, you need to disconnect the touchpad and hotkeys cables.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
adammw
회원 가입일: 01/21/11
111 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 3,165
