이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Turn off the power and remove the battery before working on your Eee PC
Start by removing the keyboard
There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
다른 한 분이 해당 안내서를 완성하였습니다.
