주요 콘텐츠로 건너뛰기
Disassembling Beaba Lutin night lamp
필요한 것
  1. Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 1 단계, 이미지 1/3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 1 단계, 이미지 2/3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 1 단계, 이미지 3/3
    • The lamp opens up at the base: there are two smaller tabs next to the button, the semi-transparent plasic can be pressed in a bit with a knife, put a bit of paper inbetween to prevent the clip from snapping back. Next go with a knife towards one of the large tabs on the side until one side snaps out. Repeat for other side.
  2. Disassembling Beaba Lutin night lamp: 2 단계, 이미지 1/3 Disassembling Beaba Lutin night lamp: 2 단계, 이미지 2/3 Disassembling Beaba Lutin night lamp: 2 단계, 이미지 3/3
    • Remove the 4 screws (warning: 2x2 different types), out comes the pcb. Detach battery connector at the back.
  3. Disassembling Beaba Lutin night lamp: 3 단계, 이미지 1/3 Disassembling Beaba Lutin night lamp: 3 단계, 이미지 2/3 Disassembling Beaba Lutin night lamp: 3 단계, 이미지 3/3
    • remove two more screws to get at the battery
  4. Disassembling Beaba Lutin night lamp: 4 단계, 이미지 1/1
    • Overview of parts
결론
다른 5명이 해당 안내서를 완성하였습니다.
petur
회원 가입일: 07/23/11
508 평판
안내서 3개 작성하였습니다
댓글 3개
I think it is easier to open the lamp by pressing the semi-transparent part at the opposite side of the button.
Matthieu Morel - 답글
How can I open the lamp??? Please post a photo of how are u using the knife because I can't!!!
Alberto Santaella Gallego - 답글
you need to press the clips inward, the picture shows where the clips are. Slide inbetween and press
petur - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 51
전체 시간: 3,481
