이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The following guide will help with the safe disassembly of the casing and the two separate the sides of the device. Follow each step carefully as to not damage the device.
필요한 것
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using a ESD-safe Philips #0 Screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two Philips #0 screws with the ESD-safe screwdriver.
Slowly remove the center band and 2 clip rings until the adhesive separates.
Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in red.
Open the device to separate the two main bodies of the device. The device should look as picture number 3.
Remove the speaker wire(yellow, red, black, white) from the mother board.
To reassemble your device, simply follow the disassembly guide in reverse. If you have questions or concerns about the disassembly of your device, please see the device page or troubleshooting page for the Beats Pill 1.0 for more information.
다른 5명이 해당 안내서를 완성하였습니다.
