소개
The outer casing must be removed to replace any internal component of the Blackberry 8820.
To remove the outer casing of the Blackberry 8820, you must have a 1/16 inch diameter torx screwdriver ready as well as a plastic removing tool.
필요한 것
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
