주요 콘텐츠로 건너뛰기
Disassembling Breville BKC600XL Coffee Brewer Head
필요한 것
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 1 단계, 이미지 1/3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 1 단계, 이미지 2/3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 1 단계, 이미지 3/3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: 2 단계, 이미지 1/1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 3 단계, 이미지 1/3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 3 단계, 이미지 2/3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 3 단계, 이미지 3/3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Antonio
회원 가입일: 09/26/12
120 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - 답글
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 4,155
