주요 콘텐츠로 건너뛰기
Disassembling Canon EOS 60D Removing Back Panel
필요한 것
  1. Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: 1 단계, 이미지 1/2 Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: 1 단계, 이미지 2/2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Disassembling Canon EOS 60D Removing Back Panel: 2 단계, 이미지 1/2 Disassembling Canon EOS 60D Removing Back Panel: 2 단계, 이미지 2/2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
  3. Disassembling Canon EOS 60D Removing Back Panel, Rubber grips: 3 단계, 이미지 1/1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  4. Disassembling Canon EOS 60D Removing Back Panel, Left-Side Port Cover: 4 단계, 이미지 1/1
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  5. Disassembling Canon EOS 60D Removing Back Panel: 6 단계, 이미지 1/1
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  6. Disassembling Canon EOS 60D Removing Back Panel: 7 단계, 이미지 1/1
    • Slide the rear part of the cover out.
  7. Disassembling Canon EOS 60D Removing Back Panel: 8 단계, 이미지 1/2 Disassembling Canon EOS 60D Removing Back Panel: 8 단계, 이미지 2/2
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eric D
회원 가입일: 11/13/12
1,284 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 5,019
