주요 콘텐츠로 건너뛰기
Disassembling Canon EOS Rebel XS Battery Door
필요한 것
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Battery Door: 2 단계, 이미지 1/1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: 3 단계, 이미지 1/1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Battery Door: 4 단계, 이미지 1/1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: 5 단계, 이미지 1/1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Disassembling Canon EOS Rebel XS Battery Door: 6 단계, 이미지 1/1
    • Use your fingertip to pry off the external shutter port cover.
  7. Disassembling Canon EOS Rebel XS Battery Door: 7 단계, 이미지 1/1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Disassembling Canon EOS Rebel XS Battery Door: 8 단계, 이미지 1/3 Disassembling Canon EOS Rebel XS Battery Door: 8 단계, 이미지 2/3 Disassembling Canon EOS Rebel XS Battery Door: 8 단계, 이미지 3/3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Disassembling Canon EOS Rebel XS Battery Door: 9 단계, 이미지 1/1
    • Once the grip is loose, use your fingers to remove it from the camera.
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: 10 단계, 이미지 1/1
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
  11. Disassembling Canon EOS Rebel XS Battery Door: 11 단계, 이미지 1/2 Disassembling Canon EOS Rebel XS Battery Door: 11 단계, 이미지 2/2
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
결론
Daniel Bussone
회원 가입일: 01/28/11
1,251 평판
안내서 11개 작성하였습니다
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 회원
CPSU-REGAN-W11S3G41
2 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 4,987
