주요 콘텐츠로 건너뛰기
Disassembling Canon EOS Rebel XS Front Cover
필요한 것
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: 2 단계, 이미지 1/1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: 3 단계, 이미지 1/1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: 4 단계, 이미지 1/1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Bussone
회원 가입일: 01/28/11
1,251 평판
안내서 11개 작성하였습니다
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 회원
CPSU-REGAN-W11S3G41
2 회원들
안내서 21개 작성하였습니다
댓글 2개
This should be labelled: Easy.
tjt263 - 답글
Okay, there are several steps missing.
tjt263 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 5,275
