주요 콘텐츠로 건너뛰기
Disassembling Canon Pixma MP480 Rear and Side Panel
필요한 것
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 1 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 1 단계, 이미지 2/2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: 2 단계, 이미지 1/1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
    "quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
    Perhaps Fuzz - 답글
    Thank you, Perhaps Fuzz. Thank you.
    Marji Zintz -
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: 3 단계, 이미지 1/1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: 4 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel: 4 단계, 이미지 2/2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: 5 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel: 5 단계, 이미지 2/2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: 6 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel: 6 단계, 이미지 2/2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: 7 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel: 7 단계, 이미지 2/2
    • Flip the printer over so that you are facing the bottom of the printer.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: 8 단계, 이미지 1/2 Disassembling Canon Pixma MP480 Rear and Side Panel: 8 단계, 이미지 2/2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Kevin Cole
회원 가입일: 01/17/13
116 평판
안내서 1개 작성함
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 회원
CPSU-REGAN-W13S19G41
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Where is the rest of disassembly?
bill roberts - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 22
전체 시간: 21,141
