주요 콘텐츠로 건너뛰기
Disassembling Canon PowerShot A590 IS Front Cover
필요한 것
  1. Disassembling Canon PowerShot A590 IS Front Cover, Batteries: 1 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot A590 IS Front Cover, Batteries: 1 단계, 이미지 2개 중 2개
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Disassembling Canon PowerShot A590 IS Front Cover: 2 단계, 이미지 1개 중 1개
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Disassembling Canon PowerShot A590 IS Front Cover: 3 단계, 이미지 1개 중 1개
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Disassembling Canon PowerShot A590 IS Front Cover, Back Cover: 4 단계, 이미지 1개 중 1개
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Disassembling Canon PowerShot A590 IS Front Cover: 5 단계, 이미지 1개 중 1개
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Disassembling Canon PowerShot A590 IS Front Cover: 6 단계, 이미지 1개 중 1개
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Disassembling Canon PowerShot A590 IS Front Cover: 7 단계, 이미지 1개 중 1개
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Disassembling Canon PowerShot A590 IS Front Cover, Remove Lens Cover: 8 단계, 이미지 1개 중 1개
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  9. Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: 9 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: 9 단계, 이미지 2개 중 2개
    • Remove the front cover of the camera.
    • This may require a bit of force.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zach
회원 가입일: 10/11/10
284 평판
안내서 6개를 작성함
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 회원
CPSU-REGAN-F10S9G19
4 회원들
안내서 14개를 작성함
3가이드 댓글
The photos do not show a camera strap, and the instructions don't mention it. Before starting disassembly, I advise removing the camera strap. It make it easier to remove and re-attach the back cover.
jwoconnor - 답글
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
brianinnes81 - 답글
l cannot get an answer to my question on why my Canon A590 will not power on.
burks817 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 49
전체 시간: 15,334
