메인 콘텐츠로 스킵하기
소개
Use this guide to remove the AV port and logic board.
부품
지정된 부품이 없습니다.
  1. Remove wrist strap and battery. Remove wrist strap and battery.
    • Remove wrist strap and battery.
  2. Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. The cases should now be removed.
    • The cases should now be removed.
    This can be a bit tricky when reassembling. All of the little tabs around the edge need to snap into their proper places, and there are three cover pieces to manage. Plus, you need to make sure that the camera/video/playback switch is properly engaged with its slider on the circuit board, otherwise you'll need to raise the back panel and reposition everything again.
    Craig Bonsignore - 답글
    oh yes , i agree lol
    elbala80 -
  5. Remove the top-left screw above the LCD screen (0.100 in). Remove the C-shaped plate from the side of the LCD screen.
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Remove the screw from the top-right of the LCD screen (0.098 in). Remove the L-shaped bar from the right of the LCD screen.
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
    I used this guide for a blue "made in china" version of this camera, as well as a silver "made in japan" version. The L-shaped brackets on either side of the LCD were much easier to remove for the blue one, but I was able to get them out for the silver one also with some additional coaxing. There were more pronounced tabs/notches securing the brackets to the adjacent frame on the silver one.
  7. Use the spudger to remove the L-shaped bar from the left-side of the LCD screen. Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
    There is a hole in the reinforced "plug" end of the LCD cable shown in Step 8. You can use a dental-type pick to remove and replace the plug easily.
    Edward Pinnell - 답글
  9. Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera. Use the tweezers to lift this ribbon. Use the tweezers to gently peel this ribbon from the one underneath it.
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  11. The LCD screen should now be removed.
    • The LCD screen should now be removed.
  12. Remove the screw located on the side of the camera (0.072 in).
    • Remove the screw located on the side of the camera (0.072 in).
  13. Use the spudger to remove the lens ribbon from the circuit board. Use the spudger to lift the ribbon.
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  14. Disconnect the flash assembly ribbon. The flash assembly ribbon is located underneath the lens assembly ribbon.
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  15. Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  16. The capacitor should now be removed.
    • The capacitor should now be removed.
  17. Remove 4 screws from silver plate (0.106 in).
    • Remove 4 screws from silver plate (0.106 in).
  18. Use spudger to lift the second lens ribbon. Remember the first ribbon was removed while taking out the flash assembly.
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  19. Use spudger to carefully lift the LED light off the upper-left corner of the lens. Use spudger to carefully lift the LED light off the upper-left corner of the lens.
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
    This step omits the removal of the shutter release assembly shown in position in Step 17. Picture in Step 18 shows release assembly removed. Release assembly can be removed and set aside taking care to not disturb connection wires to expose LED light so it can be pried off the lens assembly as shown in second photo of this step.
    Mike Lione - 답글
  20. Remove the lens. Remove the lens.
    • Remove the lens.
  21. The camera lens should now be removed.
    • The camera lens should now be removed.
  22. Remove screw from top-right of logic board (0.102 in). Remove screw on the silver plate (0.102 in).
    • Remove screw from top-right of logic board (0.102 in).
    • Remove screw on the silver plate (0.102 in).
  23. Remove screw from bottom-right of logic board board (0.102 in). The tripod connector can now be removed.
    • Remove screw from bottom-right of logic board board (0.102 in).
    • The tripod connector can now be removed.
  24. Remove screw (0.102 in) from the left side of the logic board.
    • Remove screw (0.102 in) from the left side of the logic board.
  25. Using the spudger, disconnect the ribbon cable located on the top of the logic board. Using the spudger, disconnect the ribbon cable located on the top of the logic board.
    • Using the spudger, disconnect the ribbon cable located on the top of the logic board.
  26. The logic board may now be removed from the frame. The logic board may now be removed from the frame.
    • The logic board may now be removed from the frame.
  27. Remove the remaining screw (0.102 in) located on the camera strap piece. The camera strap piece and the av port/battery/memory card assembly can now be removed. The camera strap piece and the av port/battery/memory card assembly can now be removed.
    • Remove the remaining screw (0.102 in) located on the camera strap piece.
    • The camera strap piece and the av port/battery/memory card assembly can now be removed.
  28. This is the final product.
    • This is the final product.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Grossheim
회원 가입일: 2011년 01월 25일
1,386 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 회원
CPSU-REGAN-W11S3G32
3 회원들
안내서 8개 작성하였습니다
The lens seems to be misaligned with the hole on the front frame. Has anyone had this problem? If so can you please let me know if it's something simple I'm doing or not doing. Thank you.
David - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,521
