주요 콘텐츠로 건너뛰기
Disassembling Canon PowerShot SD1100 IS Camera Lens
필요한 것
  1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: 1 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: 1 단계, 이미지 2개 중 2개
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Camera Lens: 2 단계, 이미지 3개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 2 단계, 이미지 3개 중 2개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 2 단계, 이미지 3개 중 3개
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Camera Lens: 3 단계, 이미지 3개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 3 단계, 이미지 3개 중 2개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 3 단계, 이미지 3개 중 3개
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Camera Lens: 4 단계, 이미지 1개 중 1개
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: 5 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: 5 단계, 이미지 2개 중 2개
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS Camera Lens: 6 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 6 단계, 이미지 2개 중 2개
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS Camera Lens: 7 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 7 단계, 이미지 2개 중 2개
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS Camera Lens: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS Camera Lens: 9 단계, 이미지 3개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 9 단계, 이미지 3개 중 2개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 9 단계, 이미지 3개 중 3개
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS Camera Lens: 10 단계, 이미지 1개 중 1개
    • The LCD screen should now be removed.
  11. Disassembling Canon PowerShot SD1100 IS Camera Lens, Flash Assembly: 11 단계, 이미지 1개 중 1개
    • Remove the screw located on the side of the camera (0.072 in).
  12. Disassembling Canon PowerShot SD1100 IS Camera Lens: 12 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 12 단계, 이미지 2개 중 2개
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Disassembling Canon PowerShot SD1100 IS Camera Lens: 13 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 13 단계, 이미지 2개 중 2개
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Disassembling Canon PowerShot SD1100 IS Camera Lens: 14 단계, 이미지 1개 중 1개
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  15. Disassembling Canon PowerShot SD1100 IS Camera Lens: 15 단계, 이미지 1개 중 1개
    • The capacitor should now be removed.
  16. Disassembling Canon PowerShot SD1100 IS Camera Lens, Camera Lens: 16 단계, 이미지 1개 중 1개
    • Remove 4 screws from silver plate (0.106 in).
  17. Disassembling Canon PowerShot SD1100 IS Camera Lens: 17 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 17 단계, 이미지 2개 중 2개
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  18. Disassembling Canon PowerShot SD1100 IS Camera Lens: 18 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 18 단계, 이미지 2개 중 2개
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
  19. Disassembling Canon PowerShot SD1100 IS Camera Lens: 19 단계, 이미지 2개 중 1개 Disassembling Canon PowerShot SD1100 IS Camera Lens: 19 단계, 이미지 2개 중 2개
    • Remove the lens.
  20. Disassembling Canon PowerShot SD1100 IS Camera Lens: 20 단계, 이미지 1개 중 1개
    • The camera lens should now be removed.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Grossheim
회원 가입일: 01/25/11
1,623 평판
안내서 6개를 작성함
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 회원
CPSU-REGAN-W11S3G32
3 회원들
안내서 8개를 작성함
1가이드 댓글
How do you CLEAN the lens?
Christian - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 23
지난 30일: 102
전체 시간: 22,734
