주요 콘텐츠로 건너뛰기
Disassembling Canon PowerShot SD850 IS Case Removal
필요한 것
  1. Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 1 단계, 이미지 1/3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 1 단계, 이미지 2/3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 1 단계, 이미지 3/3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Disassembling Canon PowerShot SD850 IS Case Removal: 2 단계, 이미지 1/2 Disassembling Canon PowerShot SD850 IS Case Removal: 2 단계, 이미지 2/2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Disassembling Canon PowerShot SD850 IS Case Removal, Case: 3 단계, 이미지 1/2 Disassembling Canon PowerShot SD850 IS Case Removal, Case: 3 단계, 이미지 2/2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Disassembling Canon PowerShot SD850 IS Case Removal: 4 단계, 이미지 1/3 Disassembling Canon PowerShot SD850 IS Case Removal: 4 단계, 이미지 2/3 Disassembling Canon PowerShot SD850 IS Case Removal: 4 단계, 이미지 3/3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Disassembling Canon PowerShot SD850 IS Case Removal: 5 단계, 이미지 1/2 Disassembling Canon PowerShot SD850 IS Case Removal: 5 단계, 이미지 2/2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Disassembling Canon PowerShot SD850 IS Case Removal: 6 단계, 이미지 1/2 Disassembling Canon PowerShot SD850 IS Case Removal: 6 단계, 이미지 2/2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Disassembling Canon PowerShot SD850 IS Case Removal: 7 단계, 이미지 1/1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Disassembling Canon PowerShot SD850 IS Case Removal: 8 단계, 이미지 1/1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Peter Tran
회원 가입일: 10/06/10
225 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 회원
CPSU-MANESS-F10S20G7
6 회원들
안내서 7개 작성하였습니다
댓글 한 개
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 4,212
