주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
How to remove the outer casing of your Canon PowerShot SD850 IS.
부품
지정된 부품이 없습니다.
  1. Using your fingernail, slide the light gray tab towards edge of camera. Slide the light gray door and pull up to open the door. In the camera shown in the photos, there is not a Memory Card or Battery.
    • Using your fingernail, slide the light gray tab towards edge of camera.
    • Slide the light gray door and pull up to open the door.
    • In the camera shown in the photos, there is not a Memory Card or Battery.
    • Both Battery and Memory Card slots should be visible.
  2. Use your fingernail and slide the small brown tab towards the edge of the camera. The battery will pop up.
    • Use your fingernail and slide the small brown tab towards the edge of the camera.
    • The battery will pop up.
    • Pull battery straight out of battery holder.
    • When putting the battery back in, make sure it the battery is oriented so the terminals connect.
  3. Remove the following 4 screws: Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Open the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera. Slide light gray door and pull up to open the door.
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Peter Tran
회원 가입일: 2010년 10월 06일
225 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 회원
CPSU-MANESS-F10S20G7
6 회원들
안내서 7개 작성하였습니다
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 3,868
